Digital panel meters sport dual displays
By Lee Teschler | November 12, 2020
The NTM-8 smart meter is part of the Otek New Technology Meter series. Following the company’s tradition of providing easy-to-install Plug & Play instrumentation, the NTM-8 is a direct form, fit and function replacement for the Foxboro 257, Bailey 775, or any other 6- or 7-inch analog meter.
Available in a metal housing, the NTM-8 carries industry standard dimensions of otek2.785×6.35 in (WxH). Able to offer a dual display, the NTM-8 can house anywhere from two to four channels, with four digits and an automatic tricolor bar display with intensity control, and can be powered by the current loop, the ac signal, or an external power source. The loop and signal options consume less than 60 mW of power, while external models feature over 30 signal conditioners.
Additional features of the NTM-8 include an input failure alarm with run time stamp that alerts the operator in the event of a dead or lost signal, self-diagnostics, isolated serial I/O or USB/RS485, math functions (+, -, x, √, ÷, X-Y tables, polynomials), four relays or open-collector transistors, optional 4-20 mA/30-V output, and a configurable bar direction (Up/Down/CenterZero)/.
As with all Otek products, the NTM-8 is warranted for the life of the instrument. Customizations and reverse engineering are welcome as well.
Otek Corp., 4016 E. Tennessee St., Tucson, AZ 85714, 520-748-7900/520-790-2808 FAX, [email protected], www.otekcorp.com
You may also like:
  • What is a Molecular Property Spectrometer sensor?
  • Electronics that operate in cryogenic cold
  • Women in Engineering — Gabi Miholics
  • What are geared cam limit switches?
  • How to calculate linear ball bushing life (and how it…
Filed Under: TECHNOLOGIES + PRODUCTS, Cabinets • enclosures • control panels
Tagged With: otekcorp
55416_commModule_APL_300dpi_cmyk
Softing introduces a hardware module for implementing Ethernet-APL field devices.
IO-Link Smart Field I/O System from AutomationDirect
50 years of bit parallel encoders from POSITAL
EXAIR 3D model and CAD Library has more than 70 extensions
