Housed in an industry-standard 1/8th DIN casing and available in either plastic or metal (for use in EMI/RFI, Mil-Std. 461 and Class 1E applications), the Signal Panel Meter (SPM) incorporates “pure white” LED technology to offer an illuminated 4½ digit, 0.6-in display, which may be customized to virtually any color simply by changing the scale plate filter. This universal display is designed to be highly customizable to a variety of consumer applications, while offering a reading that’s clear and quickly decipherable by the operator.
The SPM can be powered by its signal via 4-20 mAdc, V/mAdc, or ac Volts, Amps, Watts, and Hertz, or externally powered with options of Non-Isolated 5 Vdc, Isolated 5-48 Vdc or 90-265 Vac 50/60 Hz respectively. Highlight features of the SPM include ±0.1% accuracy, serial communications of RS232, RS485, and USB, up to four relays/O.C.T. and 4-20mA outputs, NEMA 4x displays, as well as customizable scale plates/calibration ranges.
In addition to the standard 4½-digit display, the SPM is also available in four and 3½-digit displays at 0.8 in. The SPM is also a direct plug-and-play replacement for the Ultima200 analog meter. As with all OTEK products, the SPM carries a lifetime warranty.
Otek Corp., 4016 E. Tennessee St., Tucson, AZ 85714, www.otekcorp.com, [email protected].
You may also like:
Filed Under: TECHNOLOGIES + PRODUCTS, Cabinets • enclosures • control panels
