Hoffmann + Krippner is proud to announce the availability of the new model P53-80-D18. This new compact (45mm long and 18mm diameter) ultrasonic sensor is said to be smallest ultrasonic sensors on the market worldwide and is designed for use in harsh environmental conditions as well as in hygienic applications.
Due to the special housing construction made of V4A stainless steel (1.4404) with a roughness depth of 0.6μm, the P53 STEEL HEAD is well suited for use in harsh environments such as dust, moisture and water vapor. As the sensor and its mounting assembly can be sanitized with strong cleaning materials, the P53’s real-world applications include manufacturing, food and chemical processing, medical, agriculture, packaging, etc. It can be used for a variety of distance measurements as well as level measurement, presence detection, detection of moving objects, counting objects and checking for completeness.
The new miniature P53 provides a range of up to 800 mm. The high-temperature range of up to + 80 °C opens up a wide range of applications.
The EHEDG certified model is equipped with an integrated cable screw connection, ensuring best hygiene for food and beverage as well as bottling and packing industries. The industrial model includes a M12 connector with power supply, signal output and teach in. It can be mounted with two Teflon nuts that provide acoustic decoupling. The P53 can be configured via the M12 connector cable. In addition, optional external hold/sync switches are available.
Filed Under: Sensor Tips
