Line of electrical panelboard connectors from Galvan Electrical Products now includes four and six-barrel models that accommodate conductor ranges of 500 kcmil to 4 AWG, 500 kcmil to 2 AWG, 600 kcmil to 2 AWG and 750 kcmil to 1/0 AWG. The 4ABV and 6ABV are dual-rated aluminum solderless connectors that combine conductor size and connection capacity.
Designed for use with aluminum or copper conductors, they are manufactured from high-strength 6061-T6 aluminum alloy to ensure both maximum durability and conductivity. They feature a straight mounting pad with two fastener holes to eliminate the rotation allowed by single-hole mounted lugs.
The hex-head conductor screws are designed to extend beyond the barrel sides of the connector to allow a better, more secure compression of the conductor. This design spreads the conductor strands to help dissipate heat, and improve its pull out safety features and capabilities.
The design of the chamfered-entry wire way provides optimum transfer of current, creating a straight-line flow through the connector for the least possible path of electrical resistance. A positive wire stop is also part of the design.
Galvan’s 4ABV-500, 4ABV-600, 4ABV-750, 6ABV-500 and 6ABV-750 are part of a full line of dual-rated aluminum panelboard connectors. Configurations include one-hole/two-barrel, two-hole/two-barrel, two-hole/three-barrel, two-hole/four-barrel and two-hole/six-barrel. Conductor ranges extend from 300 – 6 to 750 – 1/0.
www.galvanelectrical.com
The post Panelboard connectors appeared first on Connector Tips.
Filed Under: Connectors (electrical) • crimp technologies, MOTION CONTROL
