Miki Pulley announces Introduction of its “Paraflex” Pin-Hub Couplings for direct sale to OEM’s in North America. Key features of these couplings include high allowable misalignment, low backlash and resonance dampening.
With a pin-bushing type design, these Paraflex Couplings are available in two models. The CPU model has a maximum torque of 25 Nm and allows angular misalignment up to 4°. The CPE model has a maximum torque of 10 Nm and allows angular misalignment up to 1°. Available bore sizes range from 3.0 to 22 mm.
An important feature of these Paraflex Couplings from Miki Pulley is ease of installation. Clamp style hubs made of sintered aluminum slip easily onto two connecting shafts with the coupling locked into position with recessed tightening screws.
Handling system speeds up to 6000 rpm depending on model, Paraflex Couplings are RoHS compliant. They operate in temperature environments from -30° to +100°C. They are suitable for automated packaging systems, chip mounters, electric discharge machines, and similar applications.
Miki Pulley
www.mikipulley-us.com
Filed Under: Coupling Tips
