The new fractional horsepower parallel shaft VWDIR83 gearmotors from Bison Gear & Engineering Corp. represent a versatile, long life, value solution. Designed as Von Weise Drop-In Replacements, the Bison VWDIR83 gearmotors are available in 12 standard models; 6 each for 12 volt and 90 volt DC inputs. With gear ratios from 32:1 to 430:1, fixed output speeds range from 6 to 93 RPM, with output torques from 50 to 13 in-lbs. These Bison drop-in replacements for VW83 gearmotors feature 1/30 hp permanent magnet DC motors with replaceable brushes, grease lubrication for long life and all-position face mounting with a 50 lb. overhung load rating. Bison is also introducing a similar line of dual voltage, dual frequency AC gearmotors, powered by 1/20 hp induction motors.
Manufactured in Bison Gear’s St. Charles, Illinois facilities to the highest quality standards to ensure dependable, long-life operation, Bison’s new VWDIR83 gearmotors are available with U.L. and CSA recognition and are supported by Bison’s Innopreneurial(TM) application and design engineering capabilities to customize standard models to meet specific OEM needs.
The VWDIR83 PMDC gearmotors are part of the expanding Bison Gear line of Von Weise Drop-In Replacement gearmotors, which encompasses over 75 standard models.
Filed Under: Motion control • motor controls, Motors (gearmotors)
