Parallel Shaft Gearmotors
By Design World Staff | April 20, 2007
Designed as direct drop-in replacements for many high volume OEM applications, the Sharq 207 series parallel shaft gearmotors are the first in a family of eleven new gearmotor designs being introduced in 2007. Powered by 1/20 horsepower, UL and CSA recognized AC motors, the four standard models in the series have torque ratings from 42 to 113 lb-in., with 2 to 29 rpm output speeds at full load current of 1.3 A. Rated at 115 V, 60 Hz, the series uses shaded pole electric motors and comes standard with clockwise rotation.
The Totally Enclosed Fan-Cooled (TEFC) design gives high output in a compact 4.94 in. diameter, 7.47 in. length package. The gearmotors are also available with 1/10 horsepower open design fan-cooled motors for use in relatively clean atmospheres, with nine standard models ranging from 59 to 113 lb-in., of output torque at speeds from 2 to 56 rpm.
Sharq Motion
www.SharqMotion.com
:: Design World ::
Filed Under: Motion control • motor controls, Motors (gearmotors)
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
