Port Washington, NY — Parker’s Electromechanical Automation Division expands their line of PV gearheads. The PV115, which augments the current offering of Parker Bayside’s PV series gearheads, combines Power and Versatility by offering a wide assortment of output face options along with high radial load and output torque performance.
The output face options offer choices that have the same output face dimensions as Parker Bayside’s PX series, Alpha’s LP series, Neugart’s PLE series, Stober’s PE series as well as standard NEMA output face dimensions, which give OEMs and end users an alternative, more cost-effective solution. The PV115 also supports larger belt actuators, including Parker’s HPLA120 and HLE150.
The PV gearhead’s superior design achieves high radial loads by using precision taper roller bearings. With high input speeds and efficiency up to 97%, PV gearheads are ideal for industrial requirements, including belt and pulley, conveyor and production machinery; automotive production and inspection equipment; medical and life science applications, including lab instrumentation, device manufacturing and pharmaceutical requirements; packaging; and many other commercial
applications. The PV115 is covered by a 3-year warranty.
All Parker gearheads are proudly manufactured in the United States in our state-of-the-art facility using the most efficient Lean manufacturing practices.
Parker Motion
www.parkermotion.com
Filed Under: Gears • gearheads • speed reducers, Motion control • motor controls
