Pasternack’s Microwave & Millimeter Wave Right Angle RF Adapters
By WDD Staff | March 3, 2015
Pasternack (Irvine, CA) has expanded their lines of high frequency right angle RF adapters, which are widely used in the military and commercial markets for applications such as wireless communications, test labs, equipment racks and many other space-limited applications. The new line of microwave is offered with four in-series and between-series connector options including 1.85, 2.4, 2.92, and 3.5 mm.
The upper operating frequency for these right angle adapters ranges from 34.5 GHz with the 3.5 mm versions up to 50 GHz with 1.85mm and 2.4mm adapter versions. These right angle RF adapters also exhibit low VSWR which ranges from 1.25:1 up to 1.5:1 depending on the configuration.
A key benefit of these right angle adapters is that they allow 90 degree turns in spaces too small to accommodate the bending of many coaxial cables These adapters can also reduce excessive strain on the cables in certain tight-space applications.
Also available from Pasternack is a large portfolio of straight-body microwave and millimeter wave RF adapters including 1.0, 1.85, 2.4, 2.92, and 3.5 mm, SMP, mini-SMP and SMA. Maximum frequency levels for the straight-body versions range from 18 GHz up to 67 GHz with VSWR as low as 1.10:1. All of Pasternack’s right angle and high frequency adapters are available from stock and will ship same day they are ordered.
For more information visit www.pasternack.com.
Machine Learning for Sensors
