Patlite LR4 Series Tower Lights from AutomationDirect have a modular “Twist and Lock” system that easily customizes and reconfigures LED and sound modules. Pre-assembled two-, three- and 4-tier LED modules are available, and a fifth tier can be added.
LED modules are interchangeable and color sequences are changeable by adding or removing up to five color module choices even after installation. LED modules of the same color within a signal tower will light up simultaneously. The modules are easily added or replaced with no tool needed. Prism-cut lens design enhances LED visibility from any direction.
LED module colors correspond to color coordinated wiring so re-wiring is not necessary. An optional alarm module is available with adjustable volume and selectable sound patterns. The maximum sound volume is 85dB at 1-meter.
AutomationDirect
www.automationdirect.com/stack-lights
Filed Under: TECHNOLOGIES + PRODUCTS, Lights • signal lamps • indicators
