Patlite Introduces CLK Series LED Worklights
By Stacy Combest | February 27, 2013
Kyocera Tycom replaced problematic and expensive fluourescent lighting on their drill bit-producing CNC machines with Patlite CLK Series LED Worklights. Previously, the machines’ dim fluorescent lights provided insufficient lighting, and the harsh environmental conditions led to significant repair and replacement time and costs. CLK LED worklights have dramatically improved lighting conditions to enhance productivity, while eliminating the repair and replacement issues that were commonplace with the previous solution.
High illumination CLK Series LED Worklights feature unique micro-array lens technology that provide even light distribution with ultra-bright illuminance up to 2,100 lux, and maintain at least 70 percent of the initial brightness of 60,000 hours of operation. They feature a slim profile aluminum or stainless steel body that is resistant to water, oil and chemicals, which makes them easy to clean and simple to install, and provide low cost of ownership with minimal power consumption.
PAT508_CLK_Series_lores
IP66G, IP67G and IP69K-rated CLK series LED worklights offer one-touch installation as standard – users simply slide the CLK series onto the mounting bracket and lock it in place with a locking screw. Available options include M12 quick disconnect cables and M12 quick disconnect daisy link cables that enable up to five CLK units to be operated in series, depending on the model. Their robust design, long life, reliable operation and even light distribution are ideal for machine tool, production equipment, food and beverage, packaging, pharmaceutical, aerospace, electrical panel, chemical and other harsh application environments.
Kyocera Tycom
www.KyoceraTycom.com
PATLITE
www.patlite.com
Tagged With: Patlite
