Patlite introduces LS7-9 Series Signal Light Towers which feature an elegant, smooth surface design that is IP69K rated to withstand high-pressure and high-temperature washdown operations. Additionally, with no exposed screws, shafts or other metals components, the LS7-9 is ideally suited for sanitary environment applications such as the food and beverage industry, as well as equally stringent, harsh industrial settings on machine tools and production equipment. The stackable design with optional M12 quick disconnect significantly simplifies installation and can reduce costs by eliminating the need for a separate relay box.
LS7-9 signal towers strike the perfect balance of form and flexibility to deliver an elegant look with functionality that satisfies the signaling needs of a wide range of applications, says Paul Mizuki, Marketing Manager. From the streamlined footprint and smooth surface design to the range of colors and other options, the LS7 delivers a truly built-in look, feel and sounds that harmonizes with machinery.
LS7-9 series signal towers feature a state-of-the-art inner lens design that emits a sharper and more efficient LED light than is available with other signal tower designs. Models are available in three or five light tier configurations with a wide range of user-selected colored LED light arrangements. A durable shock resistant polycarbonate lens ensures long life and reliable operation. An optional 2000 Hz to 3000 Hz buzzer emits a sound frequency that can “cut through” the sound from operating machinery that would normally drown out other buzzer sounds.
Patlite
www.patlite.com
Filed Under: TECHNOLOGIES + PRODUCTS, Electronics • electrical, Lights • signal lamps • indicators
