PbSe Position Detectors from Cal Sensors
By Design World Staff | April 25, 2011
By Design World
Cal Sensors has developed custom lead selenide (PbSe) multi-channel infrared position detection technology with market-leading sensitivity of 1.5 x 1010 Jones in the 1 to 5 µm wavelength region.
Position Sensing Board and Detector
The PbSe position detectors can quickly identify and track the location of infrared sources. The multi-channel format further allows the technology to zoom in on hot spots or other infrared emissions. This makes the infrared position detectors ideal for a wide range of applications including weapons targeting, security and defense counter-measures and hot spot detection for fire fighting.
The position sensing detectors are compact in size, making them ideal for portable or concealed applications where size is a key concern.
Cal Sensors provides expert design support to create position detection solutions designed for optimal performance in each unique application. The detectors can be arranged in a coplanar format or made to face each of the four directions with a slanted orientation to provide both directional and height input for complete 360° anaylsis accross two dimensions. Integrated software provides real-time streaming data on target position relative to detector location.
Cal Sensors
www.calsensors.com
Filed Under: Sensors (position + other), Test + measurement • test equipment
mti
MTI
moog
