    • On the Floor
PC/104-Plus dual channel Gigabit Ethernet module connects to embedded networks
By atesmeh | May 21, 2012
WinSystems announced a two channel, Gigabit Ethernet LAN module designed to offer flexible, high-performance networking connectivity for industrial embedded applications. Named the PPM-GIGE-2, it offers self-stacking I/O expansion on PC/104, EPIC, and EBX SBCs based on the industry-standard PC/104-Plus form factor. This add-in module uses standard RJ-45 connectors to plug into 10/100/1000 Mbps networks using standard Category 5 (CAT5) unshielded twisted pair (UTP) copper cables. The PPM-GIGE-2 uses two Realtek RTL8110s Ethernet controllers. They are supported by a wide range of operating systems including Windows, Linux, and other x86 real time operating systems. These onboard Gigabit Ethernet controllers combine a triple-speed, IEEE 802.3 compliant Media Access Controller (MAC) with a triple-speed Ethernet transceiver, 32-bit PCI bus controller, and embedded memory. With state of-the-art DSP technology and mixed-mode signal technology, it offers high-speed transmission over CAT 5 UTP cable. Functions such as crossover detection and auto-correction, polarity correction, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, and error correction are implemented to provide robust transmission and reception capability at gigabit data speeds.
WinSystems
817-274-7553, www.winsystems.com
  • Industrial automation accelerates with increased capital spending
    • On the Floor
