PC/104 Hardware Mounting Kits from Keystone Electronics
By Laura Carrabine | November 15, 2011
Keystone Electronics offers a new series of Hardware Mounting Kits for PC/104 and PC104-Plus Bus Drives.  The kits are ideal for limited space design/installation applications.
Keystone-easy-mount-kits
Engineered to ease assembly of new modules and multi-board stacks, the PC/104 and PC/104-Plus kits may be used with any of the more than one hundred different PC/104 modules available in the marketplace.
Each of Keystone’s PC/104 hardware mounting kits includes all the hardware required to mount a single-board and is supplied with 4 each: #4-40 threaded spacers .600” length, #4-40 x 1/4 screws, and nuts. For kits with Brass components, request Catalog #8799-4; for kits with Aluminum components request Catalog #6799-4; for kits with Stainless Steel components request Catalog #5799-4; and for kits with Nylon components request Catalog #4799-4.
www.keyelco.com
Filed Under: Fastening + joining • locks • latches • pins, Screws • nuts • bolts
C2 lever latch offers auto-relock functionality and modern appearance
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
