Line of printed circuit board connectors is extended to 3.81 mm pitch. The connectors increase your freedom in the design of signal terminations on printed circuit boards.
They are 100% interchangeable to the industry standard and suitable for all applications including wire-to-board, board-to-wire, wire-to-wire and board-to-board. Plugs are available with Push-In clamping technology to reduce wiring time up to 70% over traditional screw terminations. The connectors are also available with optional release levers to ensure the wires are not pulled out inadvertently when the connector is unplugged.
Weidmuller
www.weidmuller.com
Filed Under: Connectors (electrical) • crimp technologies, Electronics • electrical
