PCB Piezotronics Inc. of MTS Systems Corp. now sells two industrial case-isolated cryogenic ICP accelerometers — Models 637A06 and 638A06 — for use in low-temperature applications such as cryogenic centrifugal and reciprocating pumps.
They are suitable for liquefied natural gas (LNG) processing; industrial gas processing (argon, helium, hydrogen, nitrogen and oxygen); pharmaceutical production (statin drugs, biotech products such as vaccines); and frozen food production and storage.
The Model 637A06 and 638A06 accelerometers feature:
- Specialized cryogenic circuitry and quartz shear sensing technology to promote survivability in extremely cold applications
- Low temperature coefficient of sensitivity to ensure accurate measurements throughout the wide operating temperature range
- Electrically case isolated to prevent noise issues and ground loops without the added height or weight of an accessory isolation base
- Welded, hermetically-sealed housing of 316L stainless steel and rugged two-pin MIL connector to withstand the harshest industrial environments
An array of cable assemblies are available to support the launch of Models 637A06 and 638A06.
PCB Piezotronics Inc. is a designer and manufacturer of microphones, vibration, pressure, force, torque, load, and strain sensors, as well as the pioneer of ICP technology used by design engineers and predictive maintenance professionals worldwide for test, measurement, monitoring, and control requirements in automotive, aerospace, industrial, R&D, military, educational, commercial, OEM applications, and more. For more information, download this PDF on www.pcb.com.
Filed Under: Sensor Tips
