PCB Piezotronics Inc. of MTS Systems Corp. now sells Models 421B30, 421B31 and 421B3X differential charge amplifiers designed for use with differential charge mode accelerometers and pressure sensors. The products were developed for use in power generation turbine research and development and rotating asset monitoring in nuclear facilities.
The product features:
- Variety of input sensitivities allows pairing with charge-mode accelerometers and pressure
- Ability to convert from an input sensitivity in one engineering unit to an output signal in a different engineering
- Voltage (mV) and current (µA) outputs for flexibility in applications with long signal transmission distance
- Configurable high-pass and low-pass filters allow for application-specific frequency
For all technical inquiries and application support, please contact Meredith Christman at [email protected] or 716-684-0003 x2071.
PCB Piezotronics, Inc. is a designer and manufacturer of microphones, vibration, pressure, force, torque, load, and strain sensors, as well as the pioneer of ICP technology used by design engineers and predictive maintenance professionals worldwide for test, measurement, monitoring, and control requirements in automotive, aerospace, industrial, R&D, military, educational, commercial, OEM applications, and more. For more information, visit pcb.com.
Filed Under: Sensors (position + other)
