PCB Piezotronics, Inc., a wholly owned subsidiary of MTS Systems Corporation (NASDAQ: MTSC), has released its smallest, 0.47-in. (11.8 mm), ground isolated, miniature triaxial cube accelerometers with TEDS (Transducer Electronic Data Sheet).
Models J356A43 / 44 / 45 join the family of miniature triaxial ICP accelerometers with TEDS that are ideal for modal and structural analysis, electric automotive NVH, and package testing. Available in three ranges, 50 g / 100 g / 500 g, these accelerometers greatly reduce signal noise from electrical interference, or poor grounding, as the sensors are electrically isolated from the mounting surface. These accelerometers achieve ground isolation with use of a very thin layer of nonconductive glass-filled epoxy and a three-sided titanium shell, achieving excellent mechanical coupling without significantly increased weight.
Highlights:
– Ground isolation
– Wide frequency bandwidth
– Hermetically-sealed titanium housing
PCB Piezotronics
www.pcb.com
Filed Under: Sensor Tips
