TORRANCE, CA – Shifting loads and loose cargo are not a problem for Pelican-Hardigg™ Inter-Stacking Pattern (ISP) Cases.
Designed to stay secure in transit, ISP Cases are engineered with patent-pending “wave design” stacking ribs (on their lids) and molded in-discs (on their bottoms) that work in tandem to lock the cases together in a stack. The integrated wave design also allows for easy cross-stacking across all six models in the group and enhances their rotationally molded polymer construction’s load bearing properties.
Optimized for most known pallet sizes including the U.S. Military’s new Joint Modular Intermodal Container (JMIC) system, the ISP Cases are available in 6 sizes that can accommodate for a range of 4 to 25 cubic feet of usable storage space.
Standard features include an o-ring seal (to ensure that the case stays secure and watertight in transit), an internal atmospheric purge valve, and up to eight “comfort grip” high-impact polymer handles (for easy team lifting). Lockable steel cable catches with cobalt finish and an integrated card label holder also come standard on all models. For easy one-person transit edge casters are included on select models. Skid runners are included on larger models.
ISP Cases are available in black, grey, desert tan, OD green and Safety Red along with a host of optional features that include stainless steel hardware as well as a choice of purchasing the case with or without layers of polyethylene foam.
Pelican Products, Inc.
www.Pelican.com
Filed Under: Materials • advanced, Safety systems + components
