PEM Self-clinching Locknuts from PennEngineering
By Patrick Curran | May 10, 2010
PEM® self-clinching prevailing torque locknuts provide ideal solutions to prevent mating hardware from loosening in service due to vibration or other application-related factors. This growing family of fasteners includes a variety of types and different locking-feature styles to satisfy a wide range of applications. Their use can save time and money compared with alternative chemical locking methods or patches.
PEM-Locknuts
PEMHEX® locknuts integrate a nylon hexagonal element to create a reusable, non-metallic prevailing torque thread lock that eliminates possible galling and any need for lubricant; TRI-DENT® locknuts achieve prevailing locking torque using an indenting process that deforms the top thread; PEMFLEX® locknuts feature two rugged, semicircular flexing jaws that prevent loosening of mating hardware in especially severe service applications; and miniature locknuts and floating types develop prevailing locking torque through a process that elliptically squeezes the tops of the fasteners. All PEM clinch locknuts install permanently in thin metal sheets.
Depending on type, PEM locknuts demonstrate thread-locking performance equivalent to applicable NASM25027 specifications or meet relevant IFI or ANSI torque requirements. Versions are available in steel, stainless steel, or aluminum and in thread sizes from #2-56 and M2.5 through #10-32 and M5.
PennEngineering®
www.pemnet.com
Filed Under: Fastening + joining • locks • latches • pins, Screws • nuts • bolts, Shocks + vibration control • gas springs
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
