  • Articles
    • Electrical/Electronic
    • Factory Automation
  • Suppliers
  • 3D CAD Models
    • 2018 Winners
    • 2017 Winners
    • 2016 Winners
    • 2015 Winners
    • 2014 Winners
    • 2013 Winners
  • Engineering Resources
    • maxon motor driven
    • 3D Product Focus
      • Helical Machined Springs
    • Totally Integrated Automation
PEM SFN spinning flare nuts eliminate loose fasteners in thin metal sheet attachment applications
By Leslie Langnau | August 14, 2018
PEM SFN spinning flare nuts from PennEngineering become permanently captivated upon installation in thin metal sheets and, when paired with a self-clinching stud or other fixed externally threaded hardware, can eliminate all loose fasteners (including flange nuts) in attachment applications. These one-piece, flanged hex nuts additionally will spin freely in a sheet enabling quick attachment to mating hardware. Their use ultimately promotes savings in assembly time and costs.
PEM SFN steel spinning flare nuts install in steel, stainless steel, or aluminum sheets of any hardness and as thin as 1mm. They are available in metric thread sizes M5, M6, and 8.
Permanent installation is accomplished by inserting the nut into a properly sized, pre-punched, and embossed mounting hole in a metal sheet and then applying sufficient squeezing force to flare the fastener’s shank. When installed, the part will appear identical to a standard flanged hex nut above the sheet and will remain flush on the other side.
Detailed specifications, fastener drawings and 3D models, and performance data (Bulletin SFN) for these RoHS-compliant fasteners can be viewed and downloaded for free at www.pemnet.com.
Founded in 1942, PennEngineering (Danboro, PA, USA) is a global leader in the fastening industry with technical and manufacturing facilities in North America, Europe, and Asia supported by a global engineering-focused sales force and a worldwide network of authorized distributors.
PennEngineering
www.pemnet.com
DW EE Editions
Covering Microcontrollers, DSP, Networking, Analog and Digital Design, RF, Power Electronics, PCB Routing and much more
Tweets by @DesignWorld
  • Enews Signup
Copyright © 2019 WTWH Media, LLC. All Rights Reserved. The material on this site may not be reproduced, distributed, transmitted, cached or otherwise used, except with the prior written permission of WTWH Media. Site Map | Privacy Policy | RSS
  • Articles
  • Suppliers
  • 3D CAD Models
    • 2018 Winners
    • 2017 Winners
    • 2016 Winners
    • 2015 Winners
    • 2014 Winners
    • 2013 Winners
    • 3D Product Focus
We use cookies to personalize content and ads, to provide social media features and to analyze our traffic. We also share information about your use of our site with our social media, advertising and analytics partners who may combine it with other information that you’ve provided to them or that they’ve collected from your use of their services. You consent to our cookies if you continue to use this website.OkRead more
