PEM SMTSK unthreaded standoffs permanently surface mount on printed circuit boards to enable quick attachment and removal of stacked components without requiring screws or tools. Their barrel design allows for a stacked board or panel to be slipped easily into place and then detached by simply sliding the component sideways and lifting it off. These standoffs serve to attach and space components either horizontally or vertically using minimal hardware and fewer assembly operations.
The standoffs are supplied on tape and reel compatible with existing SMT automated installation equipment and will mount on printed circuit boards in the same manner and at the same time as other surface mount components prior to the automated reflow solder process. These hardware solutions can reduce handling issues, risks of board damage, and costly scrap, while promoting streamlined production and “screwless” designs of subassemblies.
PEM SMTSK standoffs are manufactured from carbon steel and available in unified lengths .125”, 250,” and .375” and in metric lengths 3 mm, 4 mm, 6 mm, 8 mm, and 10 mm. They will install successfully in boards as thin as .060” and 1.53 mm.
PennEngineering
www.pemnet.com
Filed Under: Fastening + joining, MOTION CONTROL
