PEM® StickScrew® System
By Laura Carrabine | September 23, 2010
The PEM® StickScrew® System for small-screw insertion has been re-engineered with a new lower-cost StickShooter™ driver offering the capability to accommodate interchangeable nose assemblies and allow for quick tooling changeover. The self-contained system combines the lightweight air-powered driver with “sticks” of serially connected hex head screws enabling automatic screw installation without handling loose screws or driving them manually. The system can serve as a practical alternative to custom-engineered and higher-cost automated screw-driving systems.
PEM-StickScrew-System
Among other benefits, the StickScrew System promotes torque reliability (due to seating torque built into the screw), increased productivity, and safer screw insertion. The system can be up-and-running with minimal operator training.
Dozens of serially connected hex head screws are supplied in “sticks” with lengths of 12”. Screws install by inserting the stick in the driver, advancing the stick of screws, squeezing the trigger, and placing the tip of the rotating screw into the hole. The screw is then driven home and twists off cleanly when precise seating torque is achieved.
The standard (in stock) product line includes thread-cutting screws from #2-56 to #6-32 and M3 in 400 series stainless steel. Other available types and sizes include machine screws and thread-forming screws in a variety of materials, including steel, brass, and aluminum, and in thread sizes from #0-80 to #8-32 and M1 to M4. Screws can be plated, black oxidized, hardened, and otherwise customized to meet application requirements.
PennEngineering
www.pemnet.com
Filed Under: Machine tool industry + subtractive manufacturing, Fastening + joining • locks • latches • pins, Screws • nuts • bolts
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
