TWINSBURG, OH — Pepperl+Fuchs introduces KC Signal Conditioners. With a slim 12.5mm wide footprint the KC modules are the most compact signal conditioners available today, with low power consumption that reduces heat output when compared with competitive signal conditioners. This makes them an ideal signal conditioning option in control rooms with limited space in both hazardous area, as well as general purpose locations.
The SIL rated KC modules deliver broad range with 3-port isolation, and are easily programmed and configured in the field with pushbutton or dip switch logic functions. They provide limit detection with form C alarm contacts, as well as fault detection and alarm functionality. Additional features include:
–Loop-powered and analog isolators
–Removable terminals reduce maintenance
–Lower cost of ownership compared to the competition
—>In a large project, KC modules smaller size can potentially reduce the number of cabinets required, eliminating the costs of additional cabinet hardware and wiring
—>Because KC modules consumes less power, users may be able to use smaller power supplies than would otherwise be required
—>Consuming less power reduces heat generation, and less heat means smaller cooling systems, further reducing cabinet space requirements
The key to process control is accuracy, both in terms of measurement and signal conditioning. The biggest threat to effective process control is the presence of ground loops. Whenever analog data is transferred through long cable runs, there is a high probability that ground loop problems will occur. A ground loop exists when multiple earth ground connections are made in a system. A difference in potential between the grounds generates an extraneous current flow in the signal conductor. The result is commonly known as noise.
Pepperl+Fuchs
www.pepperl-fuchs.com
Filed Under: Electronics • electrical, Signal analyzers
