Pepperl+Fuchs’ Miniature ML7 Photoelectric Sensors
By Design World Staff | September 12, 2008
TWINSBURG, OH ‚– Pepperl+Fuchs‚’ ML7 series miniature photoelectric sensors are now available in IP67 and IP69k protection classes, making them suitable for use in some of the harshest environments in the food and beverage industry.
The ML7‚’s IP69k rated housing provides complete protection against the water jet pressures (up 1450 psi) and temperatures (up to 80‚°C; 176‚°F) required to thoroughly clean equipment used in meat, fish, poultry, and dairy processing. In addition, these photoelectric sensors are certified by ECOLAB as compatible with the toughest cleaning agents that are commonly used in high-temperature, high-pressure jet water spray cleaning applications.
ML7 sensors measure a very compact 31mm x 23mm x 11mm, and are available in 5 different operating modes including diffuse, diffuse with background suppression, retro-reflective, retro-reflective for clear object detection, and thru-beam. Sensors can be ordered with two different lens orientations. Newer models are also available with Pepperl+Fuchs‚’ exclusive 4-in-1‚® output. 4-in-1 output automatically detects the connected load and sinks or sources as needed, simplifying selection, stocking, and installation time and costs.
www.pepperl-fuchs.com
Filed Under: SENSORS, TEST & MEASUREMENT, ELECTRONICS • ELECTRICAL
