A versatile range of U.S. EPA Tier 4 Interim/EU Stage IIIB and Tier 4 Final diesel engines, which deliver dependable and productive power for original equipment manufacturers (OEMs) in the construction, material handling and concrete industries will be exhibited by Perkins® at this year’s World of Concrete.
The engines being exhibited are:
- The 404F-22T, a 2.2 liter, 4-cylinder, turbocharged engine with a maximum power of 61 hp (45.5 kW), provides a compact, flexible power solution for OEMs as they look to build small, high performance yet cost effective machines
- The 854F-E34T, a 3.4 liter, 4-cylinder, turbocharged unit, gives a power range of between 60 hp (45 kW) and 115 hp (86 kW), all from a single engine platform
- The 1204E-E44TTA, is a 4.4 liter, 4-cylinder, twin turbo aftercooled engine, which uses a two stage turbocharger for extra power density and faster response, to produce a power range from 147.6 hp (110.1 kW) to 173.5 hp (129.4 kW)
- The 1206E-E70TTA, a 7 liter, 6-cylinder twin-turbocharged engine producing between 187 hp (140 kW) and 301 hp (225 kW), giving OEMs who may previously have chosen a larger engine, the choice of the same power from a smaller engine package
Perkins
www.perkins.com
