Industrial lighting specialist Larson Electronics announced the release of a 30 watt LED deck light equipped with a 360° spindle that allows for complete rotation while being permanently mounted.
The DL-APB-LED-30W permanent mount LED deck light from Larson Electronics provides operators with a high powered lighting solution in applications where a low voltage light is preferred. The 30 watt PAR46 LED light emitter in this unit is highly resistant to damage from shocks and vibration as well as up to 80% more efficient than incandescent lights. This LED assembly has an average lifespan rating of 50,000 hours and draws only 2.5 amps on a 12 volt DC electrical system. Producing 2,700 lumens of intense light output, this light is available in a spot beam configuration that will produce a beam 600’ long by 100’ wide.
This deck light is equipped with a 360° spindle that allows the light to make complete rotations while being permanently mounted to a surface. Located above the spindle mount, a joint allows the light to be adjusted up or down by the operator. A chrome plated knob is located on the back of the unit to adjust the vertical tilt of the light. This permanently mounted LED deck light can be mounted to any flat surface using four small screws and a rubber gasket. Twenty four inches of wiring is provided with this unit to connect to any 12 volt DC power source. A single rocker switch located on the back of the unit provides the on/off operation. The DL-APB-LED-30W is ideal for operators who are seeking a high powered, independently adjusted light source for a patio or dock.
Larson Electronics specializes in portable industrial lighting equipment, high mast light towers, explosion proof light fixtures, power distribution systems, LED lighting and more. To view their wide range of products, visit them on the web at Larsonelectronics.com or call 1-800-369-6671 for more information. Larson Electronics will be attending the 2016 OTC show in Houston, Texas from May 2nd to May 5th. Visit them at booth 6716 to inquire about their lighting solutions for many industrial applications.
Larson Electronics
larsonelectronics.com
Filed Under: Power Electronic Tips, Lights • signal lamps • indicators, Power supplies
