    • Subscribe!
PG10 Digital Pressure Gauge from APG
By Patrick Curran | October 14, 2010
LOGAN, UT – Automation Products Group, Inc. (APG) introduces the PG10 Digital Pressure Gauge. This IP65 rated indoor/outdoor gauge features a large 5.5 in. display casing, a full five-digit display with characters at 0.68 in. tall, and a 270° digital “dial” or radial bar graph that shows a user-selectable pressure range from 0 to 100%. Combined with four large set-up buttons, the result is a robust pressure monitoring solution that is simple to set-up and operate, with true at-a-glance readability.
 pg-10-gauge
Standard features include tare, peak hold, and max-min readings, as well as user-selectable units of measure and an auto-off timer. Options include two solid-state relays or SPDT mechanical relay outputs for basic to semi-advanced automation.
The gauge has an operating temperature range, from 0° to 160° F, boasts ±0.25% accuracy of full scale, and features pressure ranges from vacuum to 500 psi, or 0 to 10,000 psi. Outputs are 0-2 VDC for battery-powered units, 4-20mA for loop-powered units, and 0-5 VDC for externally powered units. Data logging provides local access to the latest 60 readings. These features and functions make the PG10 digital pressure gauge ideally suited for use in applications where visibility, functionality, and stability are of primary concern.
www.apgsensors.com
Filed Under: Sensors (position + other), Test + measurement • test equipment
mti
MTI
moog
    • Subscribe!
