With the new HeavyCORE program, Phoenix Contact customers can receive the company’s most commonly used heavy-duty connector components within days of placing an order. HeavyCORE puts stocking priority on a select group of products that boost productivity, simplify inventory management, and provide versatility during assembly and installation.
The HeavyCON line of heavy-duty rectangular connectors comprises thousands of different components that can create more than 70 million different combinations. Many common application requirements, however, can be satisfied with a select set of those components. HeavyCORE components were selected based on their technical innovations, ability to streamline the manufacturing process, and ability to simplify the bill of materials across one or multiple projects.
An online configuration tool makes it easy to specify a complete mated assembly using the most common contact inserts and contacts, cable glands and adapters, and housings. HeavyCORE options include push-in terminations, unique snap-in modular insert frames, and the flexible EVO line. The HeavyCON line is compatible with other manufacturers’ standard rectangular connectors.
Phoenix Contact
www.phoenixcontact.com/heavycore
Filed Under: Connector Tips
