PI offers a range of piezo ceramic linear actuators for applications with different size, speed and force requirements. Among them is the N-216 PiezoWalk Linear Actuator, a linear actuator designed for applications that require millimeter-range travel, high force and nanometer-scale positioning stability.
The N-216 provides 20 mm of travel, push and pull force up to 600 N and holding force up to 800 N. Depending on operating mode and feedback configuration, it can deliver open-loop resolution down to 0.03 nm and closed-loop encoder resolution of 5 nm. Its self-locking design allows it to hold position without continuous power, which can reduce heat generation and help maintain position stability over time.
The actuator is based on PI’s PiezoWalk ceramic motor drive principle. Instead of using a rotary motor, screw or gear train, it generates motion through coordinated piezo elements acting directly on a linear ceramic runner. These elements clamp, shear, release and return in sequence to produce incremental motion over millimeter-range travel. The design combines long travel with fine positioning control.
For applications that require very small corrections rather than continuous stepping, the actuator can also operate in a dithering and pico-positioning mode. This supports controlled motion for alignment, stabilization, drift compensation and precision adjustment.
The N-216 is intended for applications in optics, aerospace, astronomy, metrology, nanopositioning and semiconductor technology. In optical systems and telescope instrumentation, it can be used for mirror positioning, active optics, alignment correction and compensation for thermal or gravitational drift. In semiconductor and nanotechnology applications, it can support inspection, wafer metrology, lithography-related positioning, process control and automation. PI also cited a scientific article describing an application for the ITER nuclear fusion reactor.
The PiezoWalk principle can also be useful in environments where electromagnetic motors or lubricated mechanical drives are less suitable. Its direct-drive piezo design supports precise, non-magnetic motion and can be adapted for applications such as vacuum or cleanroom operation.
The N-216 is designed for applications that require a combination of high load capacity, long travel and fine motion control in a compact form factor. It provides an alternative to conventional motor-driven linear actuators for systems where position stability, environmental compatibility and nanometer-scale motion are important.
For more information, visit pi-usa.us.
Filed Under: Actuators
