Piab offers its patented COAX® technology in a new simplified integration platform called piCHIP. COAX® is an energy efficient ejector technology based on a multi-stage concept for creating vacuum with compressed air.
The lightweight piCHIP unit is flexible enough to surface mount quickly on a variety of materials. Having both the compressed air & vacuum ports on the same side makes it a natural for integration. If performance needs to be increased due to changes in your process, the piCHIP can be modified to double the unit’s output quite easily for faster response.
With its almost silent operation, the piCHIP is ideal for clean room operations. Medical & electronic industries are best suited to use this product in their vacuum applications.
Because COAX® Cartridges are up to twice as fast as other cartridges and provide three times more flow than a conventional ejector with the same air consumption, the piCHIP is able to provide a high performance even at low or fluctuating feed pressures (14-87 psi). Additionally, piCHIP vacuum units begin producing vacuum immediately when the pressure valve is turned on, making maximum use of the compressed air and consuming significantly less energy than traditional vacuum pumps.
Piab
www.piab.com
Filed Under: Pneumatic Tips, Pneumatic equipment + components
