PicoScope Breaks the 100,000 Waveforms per Second Barrier
By atesmeh | December 9, 2014
The latest release of the PicoScope 6 software for PC oscilloscopes has a greatly improved continuous update rate of over 100,000 waveforms per second. This is faster than any other PC oscilloscope, and beats many expensive benchtop oscilloscopes too.
As Managing Director Alan Tong explained, “When you are looking for an intermittent glitch, a faster waveform update rate lets you find it more quickly. PicoScope’s new fast persistence display mode can collect thousands of waveforms per second, overlaying them all with color-coding or intensity-grading to show which areas are stable and which are intermittent. Faults that previously took minutes to find now appear within seconds.”
The new fast persistence mode is available on all Pico oscilloscopes from the PicoScope 3000 Series upwards with the PicoScope R6.10.2 beta software or later. Using dedicated hardware inside the scope, this mode can achieve update rates up to 120,000 waveforms per second on USB 3.0 deep memory scopes such as the PicoScope 6000C/D Series. With USB 2.0 deep memory scopes the update rate can now reach 80,000 waveforms per second.
Even faster capture rates are possible using rapid trigger mode, which collects bursts of up to 10,000 waveforms at a rate of up to 1 million waveforms per second into segmented memory for later viewing. See our data sheets for the rapid triggering performance of individual PicoScope models.
All PicoScope users can download the latest software update free of charge from www.picotech.com. Even if you don’t have a PicoScope, you can download the software and run it in demo mode to find out how powerful it really is.
Detailed test results for all current series of PicoScope oscilloscopes are listed in “Oscilloscope Waveform Update Rates”.
For more information visit www.picotech.com.
Machine Learning for Sensors
