    • Subscribe!
Pittman G30A Planetary Gearbox
By atesmeh | March 14, 2012
Pittman G30A planetary gearboxes from Ametek (Harleysville, PA) are designed with maximum torque density and durability in mind. These small gearboxes are engineered to complement 5 different series of Pittman motors allowing a wide range of output torques and speeds. Features include:
  • A mounting profile of 30.5 mm (1.20”) in diameter, or 38.0 mm (1.50”) square when the optional mounting flange is used.
  • A gearbox length ranging from 33.7 mm (1.33”) to 51.2 mm (2.02”).
  • Fourteen standard reduction ratios are available ranging from 4:1 to 1296:1.
  • A maximum output load of 2.47 Nm (350 oz-in) to 8.83 Nm (1250 oz-in).
  • Incorporated sintered steel planet gears.
  • A 416 stainless steel shaft and a sintered metal output bearing.
For more information visit www.pittman-motors.com.
Filed Under: Industrial automation, Gears • gearheads • speed reducers
    • Subscribe!
