The PHQ planetary gear unit meets the need for higher accelerating torque, torsional rigidity, and tilting stiffness. Part of the ServoFit™ line, its design is based on a helical cut, four-planet system, allowing it to operate in applications with extreme requirements. It does not sacrifice torque to save on the size of a gear head. It is not only more compact, it also allows for torque increases of up to 35%.
STOBER Drives, Inc.
www.stober.com
Filed Under: Gears • gearheads • speed reducers, Mechanical, Motion control • motor controls
