    • Subscribe!
Plastic Bearings Take High Loads
By Design World Staff | December 16, 2008
When both shock and impact loads are present, such as in oscillating applications, the bearing can make all the difference.  The iglide Q is a maintenance-free alternative to bronze, metal-backed and custom injection-molded bearings. Even at maximum loads of 14,500 lb/psi, it offers a low coefficient of friction compared with other iglide plain bearings.
As with other igus bearings, it is impervious to a range of chemicals, including organic solvents, fuels, oils and fats and, is lubrication-free, corrosion- and dirt-resistant. It operates in a temperature range of ‚–40 to +275‚° F in continuous motion and can withstand short-term exposure up to 311‚° F. The iglide Q can be paired with an array of different shaft materials, such as stainless steel or hard-anodized aluminum. Its high-load capacity makes it a viable choice for material-handling machinery, scissor lifts, lift tables, amusement park rides and other applications.
igus
www.igus.com
Filed Under: Bearings, Machine tool industry + subtractive manufacturing, Motion control • motor controls
Automation 1 Family and iXC4e
49503-ACS Motion-CMxa
SDP-SI-040
    • Subscribe!
