Plastic Hollow Knurled Knobs from J.W. Winco
By Design World Staff | December 16, 2011
J.W. Winco, Inc. announced it now offers series GN 7336 Plastic Hollow Knurled Knobs, with steel tapped inserts or threaded studs, in metric sizes. Also available is the new series GN 7336-NI, with inserts or studs of stainless steel.
These RoHS compliant knurled knobs are made of glass fiber reinforced plastic with a black matte finish. Tapped inserts and threaded studs are made of made of zinc plated, blue passivated steel, or of stainless steel. The tapped inserts are standard hexagonal nuts, which are press-fitted in by machine. The threaded studs are press-fitted in by machine. Cover caps are glass fiber reinforced plastic with a light gray matte finish. Other cap colors as well as printed lettering on caps are available upon request.
JW-Winco-Plastic-Hollow-Knurled-Knobs
GN 7336 knurled knobs feature an attractive and ergonomic design. They also offer the advantage of a closed shape (no recesses on the underside) suitable for applications with hygienic requirements.
J.W. Winco
www.jwwinco.com
Filed Under: Fastening + joining • locks • latches • pins
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
