RICHMOND, VA – The complexity of machines and installations in the automation, processing and building industry has resulted in increased cabling costs. The traditional wire-to-wire cabling required at installation or commissioning between PLCs and the various inputs and outputs is very time consuming and expensive.
One of Weidmuller’s new PLC Specific Cable Interface Solutions
Weidmuller now offers a full line of pre-assembled specific Interface cables in conjunction with an expanded line of space saving universal Interface modules for a broad range of industry standard PLCs. Each pre-assembled Interface cable assembly features a jacketed round cable that is attached directly to the original connectors for each specific PLC model I/O card. This system plugs directly into the PLC I/O cards for quick and easy I/O signal termination, saving users time and money, as well as eliminating the potential of incorrect wiring.
The new line features several connector styles to accommodate the choice and type of signals to connect to the PLC Interface boards. For standard digital signals, fully protected flat connectors are available. These feature housing and strain relief to protect against pull forces, and provide polarized and secure connections. A shielded Sub-D connector (15, 25 or 37 pole options) with shielded 24 AWG cabling is offered to properly protect and transmit sensitive analog signals. Industrial connectors rated up to 250V and 8A are available for higher voltage signals.
The portfolio of PLC Interface boards includes 40 passive boards, 15 relay boards for digital signals, and over 15 boards for analog signals. The Interface boards for digital inputs and outputs include standard voltage versions in 4, 8, 12, 16 and 32 channels, and a choice of screw or tension clamp connections. Boards in 8, 16 and 32 channels are available for higher voltage applications. Analog boards are offered in 4, 8, 9 and 16 channels. Users can choose from a variety of features including per channel LED indication, integrated fuse versions, interruptible channels for manual PLC signal switching, and special boards with force function for manual relay contact switching. Boards in 1, 2 or 3-wire systems are also available, eliminating the need and space for additional terminal blocks.
Weidmuller
www.weidmuller.com
Filed Under: Factory automation, Cables + cable management, CONNECTIVITY • fieldbuses • networks • gateways, Terminal blocks, PLCs + PACs
