    • Subscribe!
Plug-n-play safety field box for PROFINET/PROFIsafe systems
By PR Editor | August 27, 2021
Schmersal is pleased to announce the release of the SFB, a safety field box for PROFINET/PROFIsafe systems which allows simple plug-and-play installation of up to eight safety devices.
Thanks to its universal device interface with an 8-pole M12 connector, it can be used to connect a wide variety of safety devices: electronic and electro-mechanical safety interlocks, switches, sensors, light curtains and operation panels. Field box device connections can also be configured to link different devices, thus providing maximum flexibility in the conceptual design of safety solutions.
The safety signals from connected safety devices are forwarded to a safety controller for evaluation via the secure PROFINET/PROFIsafe field bus interface. PROFIsafe is the functionally safe extension to standard communication via PROFINET. PROFIsafe-based communication is protected against alteration, transmission errors, changes in the telegram sequence and similar. Parallel transmission of safety signals allows safety devices to be freely linked in the safety controller.
Schmersal
www.schmersalusa.com
Filed Under: Networks • connectivity • fieldbuses
Tagged With: schmersal
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
    • Subscribe!
