Antaira Technologies, a developer and supplier of industrial device networking and communication equipment for harsh environmental applications, announces its expansion in the industrial gigabit networking infrastructure family with the LNX-0501G-SFP and LNX-0601G-SFP series.
Antaira Technologies’ LNX-0501G-SFP series is a 5-port industrial gigabit unmanaged Ethernet switch, with 4*RJ45 10/100/1000Tx and 1*dual rate 100/1000 SFP slot. The LNX-0601G-SFP series is a 6-port industrial gigabit unmanaged Ethernet switch, with 5*RJ45 10/100/1000Tx and 1*dual rate 100/1000 SFP slot. Each series has a low power consumption that is less than 7W and has a 12~48 Vdc power input range that can support MDI/MDI-X functions and 9.6 Kbytes jumbo frames. This makes it ideal for applications that demand high bandwidth and long distance communication.
This product series provide a high EFT, surge (2,000 Vdc), and ESD (6,000 Vdc) protection to prevent any unregulated voltage and can support the power redundancy feature using a dual power input design with reverse polarity. There is also a built-in relay warning function to alert maintainers when power failures occur.
Antaira’s new LNX-0501G-SFP and LNX-0601G-SFP series have been designed to fulfill special needs within industrial automation, outdoor applications, and extreme ambient weather environments.
The IP30 rated LNX-0501G-SFP and LNX-0601G-SFP are backed by a five year warranty. These units are compact, fanless, and DIN-Rail/wall mountable. Each unit is built to withstand industrial networking hazards like shock, drop, vibration, electromagnetic interference (EMI). The unit also has temperature extreme version options for either a standard temperature range (-10 to 70°C) or an extended operating temperature range (-40 to 75°C). The model series have the dimensions of 30 x 142 x 99 mm and a unit weight of one pound (LNX-0501G-SFP) and 1.4 pounds (LNX-0601G-SFP).
www.antaira.com
Filed Under: Green engineering • renewable energy • sustainability
