Pneumatic stopper cylinders
By Editor | October 8, 2012
Stopper Cylinders are offered in 32, 40 and 50 mm bores with features and actions to meet differing application requirements. Seven rod-end styles are available with strokes of 20 and 30 mm. Shock absorbers are standard on lever/roller style models. Direction of rollers is adjustable. Magnetic pistons are standard on all models so magnetic sensors can be mounted on cylinder surfaces when input signals are required for controllers. Extruded aluminum body has counter bored thru holes for rigid mounting in limited space. Units can be double acting or single acting with spring extended rod. Double acting models can be furnished with built-in fail-safe extended rod.
08-Stopper-Cylinders_opt
Fabco-Air, Inc.
www.fabco-air.com
Filed Under: MOTION CONTROL
Tagged With: fabcoair
