Xuron Corp. has announced an air-powered wire cutter that is designed to fit comfortably in large and small hands and has a soft touch actuator for effortless high volume flush cutting in assembly and production environments.
The Xuron® Model 590 Micro-Pneumatic™ Cutter has a tapered rectangular shape that is comfortable to hold in right and left hands, regardless of size, and has a side bar requiring only 1/16″ of travel to actuate the blades. Suitable for high-volume wire cutting applications, this ergonomic hand tool eliminates manual squeezing, is torque-free, and quiet operating.
Featuring cutter blades with bypass edges that produce clean, flush cuts, the Xuron® Model 590 Micro-Pneumatic™ Cutter is offered with standard blades, blades with lead retainers, and low-profile blades for reaching into tight spaces. Requiring only 50 psi air and 0.13 cfm, it incorporates an internal bellows and generates less than 60 dbA of noise.
Xuron Corp.
www.xuron.com
Filed Under: Fluid power, Pneumatic equipment + components
