PoE+ Gigabit unmanaged switch line
By Frank Tobe | November 20, 2014
Antaira-TechnologiesThe LNP-0702G-SFP and LNP-0702G-SFP-24 series is a 7-port industrial PoE+ gigabit unmanaged Ethernet switch, with 48 to 55 Vdc high voltage power input (LNP-0702G-SFP) and 12 to 36 Vdc low voltage power input (LNP-0702G-SFP-24). Each unit has five gigabit Ethernet ports that are IEEE 802.3at compliant (PoE+) on ports 1 to 4 (data and power output maximum 30 W/port) and are compatible with IEEE 802.3af PoE and the unit has two fiber dual rate (100/1000) SFP slots. The series supports MDI/MDI-X functions and 9.6 Kbytes jumbo frame.
This product series provides high EFT, surge (2,000 Vdc) and ESD (6,000 Vdc) protection to prevent unregulated voltage and can support the power redundancy feature using a dual power input design with reverse polarity protection. There is also a built-in relay warning function to alert maintainers when power failures occur.
The switches are IP30 rated, compact, fanless, DIN-Rail and wall mountable. Each series is built to withstand industrial networking hazards like shock, drop, vibration, electromagnetic interference (EMI) and temperature extremes version options in a standard -10to 70° C model range or an extended operating temperature version in a -40 to 75° C range.
Antaira Technologies
www.antaira.com
Filed Under: TECHNOLOGIES + PRODUCTS, Ethernet — cables • hubs • switches, Switches
Tagged With: antairatechnologies
Custom pneumatic conveyors for unique applications
Advantech-iDAQ-3
Advantech launches iDAQ modular DAQ
CC100 product image_1
WAGO combines PLC and remote I/O into compact controller
Siemens’ NX delivers greater cross-discipline collaboration and knowledge capture
