Pole Mount Enclosures Now Available From ROLEC
By Leslie Langnau | April 6, 2017
Plastic enclosures designed specifically for pole mounted electronics are now available from ROLEC. Its technoPLUS range features a dedicated bracket for horizontal or vertical mounting on poles, masts, street signs etc.
ROLEC technoPLUS enclosures have been built to withstand exposed outdoor locations. They are rated to IP 66 (IP 67 optional) and molded from UV stable ASA Luran (UL 94 HB). Each enclosure is pre-molded with screw ports for the mounting bracket so no machining is needed. They can be installed ‘lid closed’ to help protect the electronics inside.
Retaining straps hold the recessed lid in place if it does need to be opened – useful when the enclosures have to be installed at height or in other difficult locations. Hinged lid trims conceal the fixing screws to deter tampering and to provide further protection against the weather.
ROLEC technoPLUS is available in five sizes ranging from 5.11” x 3.54” x 2.75” to 10.62” x 6.69” x 3.54”. The standard color is Light Gray (RAL 7035). Custom colors are available on request.
Accessories include the pole/mast attachment, terminal rails and an internal mounting plate. Enclosures can be customized with CNC milling and drilling of cutouts; bespoke colors; printing and engraving of legends and logos; RFI/EMI shielding; assembly of components.
ROLEC
www.rolec-usa.com/en/Enclosures-Accessories/technoPLUS.htm
Filed Under: Cabinets • enclosures • control panels, Flanges • supports • mounts • brackets
Tagged With: rolec
rolec
Advanced HMI enclosures and suspension arms
okw
Control knobs cater to menu-driven electronics
metcase
Standard and customized 19-in rack cases, mini-racks, desktop and portable instrument enclosures
metcase
New 19-in enclosures meet latest DIN 41494, IEC 60297-3 standard
