Polycase, a US manufacturer of plastic electronic enclosures, has extended their NEMA 4X rated ML Series by adding a new size, the ML-45F. The new 5.50″ x 4.13″ x 2.44″ polycarbonate enclosures are designed for outdoor applications and are UL Listed to UL 508A and NEMA Type 1, 2, 4, 4X, 12 & 13 specifications. With a high-quality silicone gasket seal and UL94V-0 flame rating, the enclosure is competitively priced as low as $10.42 each with no minimum order requirements.
Molded in light gray UV-stabilized polycarbonate, the ML-45F offers an opaque or clear cover option. The form-fitted gasket makes the enclosure ideal for use in a wide range of environmental conditions, protecting internal electronic components from dust, dirt, and water. Additional features include molded on surface-mounting flanges, plastic PCB mounting bosses, and stainless steel screws for corrosion resistance. Optional accessories for the entire ML Series of NEMA 4X rated plastic enclosures include internal mounting panels and cable glands.
With extensive experience in CNC machining and printing, Polycase can apply cutouts and graphics to the ML Series enclosures.
Polycase
www.polycase.com
Filed Under: TECHNOLOGIES + PRODUCTS, Cabinets • enclosures • control panels, Electronics • electrical
