Larson Electronics has announced the release of a ten outlet explosion proof portable spider box that allows operators to safely operate up to 4,000 watts of lighting and electrical equipment within Class 1 Division 1 zones.
The EPL-SBO-120-10XLV explosion proof portable power distribution system from Larson Electronics is designed to provide operators using 120 volt equipment in hazardous locations with multiple outlets in areas where receptacles are limited. This wheeled power distribution system allows operators to safely operate up to 4,000 watts of lighting and electrical equipment within Class 1 Division 1 areas. This unit includes ten 12 volt twist-lock receptacles rated at 20 amps maximum each. Operators provide 120 volt power from inside or outside the hazardous location to the 4,000 watt spider box with the provided 25’ SOOW cable terminated in a 20 amp explosion proof plug. This class rated distribution assembly is mounted onto a rugged cart style frame constructed of non-sparking aluminum and powder coated for added corrosion resistance. Mobility is provided by rotating front casters and run flat rear tires, allowing operators to wheel this temporary transformer between job sites within the hazardous environment.
“This new power distribution cart allows operators to use multiple tools and equipment in locations where receptacles are limited,” said Rob Bresnahan, CEO of Larson Electronics. “It is designed for portability and convenience as well as durability.”
Larson
www.larsonelectronics.com
Filed Under: TECHNOLOGIES + PRODUCTS, Lights • signal lamps • indicators
