Posi Lock external pullers are designed with a patented Safety Cage and built with steel. They deliver performance while exceeding safety standards. The center bolt threads are designed to achieve high torque with less effort; the nut is recessed to avoid mushrooming and disfiguration from impact; the slim tapered jaws allow for easier gripping and better access to tight spots; and the Cage tops it all off, guiding the jaws for fast setup, solid contact, and safety.
A variety of accessories, including tip protectors and extended-length jaws, are also available. Please be sure to review our product instructions before using our pullers. Below is just a sample of some specifications.
Posi Lock
www.posilock.com
The post Posi Lock 2 and 3-jaw manual pullers appeared first on Bearing Tips.
Filed Under: Bearing Tips
