POSITAL announces display units for rotary encoders
By Marisa Martin | June 10, 2016
POSTAL has added a series of stand-alone digital display units to its catalog of accessories. The new units are designed to connect directly to POSITAL’s IXARC rotary encoders, TILTIX inclinometers, LINARIX linear sensors and provide a direct readout of position, rotational speed or angular displacement. unnamed
Depending on the type of sensor, the display units can be ordered with Analog, SSI or incremental inputs. Built-in output conversion (D/A or A/D) is also available, with one analog and up to four digital output channels. Teaming up a digital display with an encoder, inclinometer or linear sensor provides a simple, convenient and accurate measurement tool for on-site position or speed measurement. By taking advantage of the output channels, it is simple to integrate the sensor and display into more complex control systems. Thanks to their compact size and sturdy construction, these displays can be located close to the machinery where the sensors are mounted. This makes it practical to use them for machine setup tasks or as a cost-effective way of monitoring machine status on the factory floor.
Regardless of input type, these displays can be programmed to display angular position, linear position or rotational speed directly and to provide limit warnings or cam-follower functionality. Programming can be done through front-panel buttons or with an easy-to-use PC-based programming tool.
POSITAL
https://www.posital.com
Filed Under: Encoders (rotary) + resolvers
Tagged With: posital
POSITAL’s explosion-proof rotary encoders receive ATEX/IECEx certification
z4636-F5858-Profinet-enc-std-srgb-web
New generation industrial ethernet encoders from Kubler
Sendix M3658 encoder with IO-Link interface
Kubler- A41-product-shot
Kubler A41 draw-wire mechanism with encoder
