GPA Series Spring-Loaded Linear Position Sensors are for use in non-harsh environments for general positioning and gaging applications. They are available in a variety of ranges from ±0.050 in. (±1.25 mm) to ±2.00 in. (±50.0 mm), with a maximum linearity error of ±0.25% FRO. Constructed of stainless steel, the front end of the spring-loaded LVDT has a 1/2-20 UNF 2A thread on the housing, allowing the user to install the LVDT into a mating threaded part, or alternatively, ‘bulkhead’ mounted using two furnished hex nuts.
Macro Sensors
www.astsensors.com
Filed Under: Sensors (position + other), Test + measurement • test equipment
