A line of adjustable shaft collars that are designed to provide for the precise linear location of shaft-mounted components has been introduced by Stafford Manufacturing Corp.
Stafford Adjustable Shaft Collars have a micro-adjustable shaft collar for applications requiring repeatable fine-tune positioning in 0.0005-in. increments with 0.200-in. total adjustment; an adjustable thrust collar that provides bi-directional axial adjustability with superior holding power; and a Micro-Adjust Stop Collar Assembly that offers micrometer-like adjustability of either or both collar faces.
Designed to let users precisely locate shaft mounted components for a wide range of industrial automation, material handling, packaging, and robotics applications, Stafford Adjustable Shaft Collars are offered from stock in standard 3/8 to 1-1/2-in. bore sizes made from steel and stainless steel. Special sizes and materials can be supplied.
Stafford
www.staffordmfg.com
Filed Under: Coupling Tips
